RB750UPr2 comfortable for 3 wan load balancing and web proxy ??
Hi!
Anyone suggest me RB750UPr2 comfortable for 3 wan load balancing and web proxy??
How much traffic do you want load balance?
Rb 750 should be able to handle about 100Mbps
Under 100Mbps
Then it should work well.
If you need more power in the future you can go for something like a RB3011 or even a CCR
Any one suggest me what is the problem both are not working together
My configuration
set [ find default-name=ether5 ] comment=LOCAL name=LOCAL poe-out=off
set [ find default-name=ether1 ] comment=WAN1 name=WAN1
set [ find default-name=ether2 ] comment=WAN2 name=WAN2 poe-out=off
set [ find default-name=ether3 ] comment=Airtel name=WAN3
set [ find default-name=ether4 ] poe-out=off
/ip neighbor discovery
set LOCAL comment=LOCAL
set WAN1 comment=WAN1
set WAN2 comment=WAN2
set WAN3 comment=Airtel
/ip hotspot profile
add address=192.168.1.1/24 comment=WAN1 interface=WAN1 network=192.168.1.0
add address=192.168.2.1/24 comment=WAN2 interface=WAN2 network=192.168.2.0
add address=45.112.22.91/27 comment=Airtel interface=WAN3 network=
45.112.22.64
add address=192.168.4.1/24 comment=LOCAL interface=LOCAL network=192.168.4.0
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=drop chain=input dst-port=8080 in-interface=WAN1 protocol=tcp
src-address=0.0.0.0
add action=drop chain=input dst-port=8080 in-interface=WAN3 protocol=tcp
src-address=0.0.0.0
add action=drop chain=input dst-port=8080 in-interface=WAN2 protocol=tcp
src-address=0.0.0.0
add chain=output comment=“Accept Proxy No Limit” disabled=yes dscp=4
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=
WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=
WAN2_conn
add action=mark-connection chain=input in-interface=WAN3 new-connection-mark=
WAN3_conn
add action=mark-routing chain=output connection-mark=WAN1_conn
new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn
new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN3_conn
new-routing-mark=to_WAN3
add chain=prerouting dst-address=192.168.1.0/24 in-interface=LOCAL
add chain=prerouting dst-address=192.168.2.0/24 in-interface=LOCAL
add chain=prerouting dst-address=45.112.22.64/27 in-interface=LOCAL
add action=mark-connection chain=prerouting dst-address-type=!local
in-interface=LOCAL new-connection-mark=WAN1_conn
per-connection-classifier=both-addresses-and-ports:2/2
in-interface=LOCAL new-connection-mark=WAN2_conn
per-connection-classifier=both-addresses-and-ports:2/1
in-interface=LOCAL new-connection-mark=WAN3_conn
per-connection-classifier=both-addresses-and-ports:2/0
add action=mark-routing chain=prerouting connection-mark=WAN1_conn
in-interface=LOCAL new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn
in-interface=LOCAL new-routing-mark=to_WAN2
add action=mark-routing chain=prerouting connection-mark=WAN3_conn
in-interface=LOCAL new-routing-mark=to_WAN3
add action=mark-connection chain=output comment=
“Marking Web Proxy Connection for WAN1” disabled=yes dst-port=80
new-connection-mark=WAN1_conn per-connection-classifier=
both-addresses-and-ports:2/2 protocol=tcp
“Marking Web Proxy Connection for WAN2” disabled=yes dst-port=80
new-connection-mark=WAN2_conn per-connection-classifier=
both-addresses-and-ports:2/1 protocol=tcp
“Marking Web Proxy Connection for WAN3” disabled=yes dst-port=80
new-connection-mark=WAN3_conn per-connection-classifier=
both-addresses-and-ports:2/0 protocol=tcp
add action=mark-connection chain=prerouting comment=
“Excluding Port 80 from PCC WAN1” disabled=yes dst-address-type=!local
dst-port=!80 in-interface=LOCAL new-connection-mark=WAN1_conn
per-connection-classifier=both-addresses-and-ports:2/2 protocol=tcp
“Excluding Port 80 from PCC WAN2” disabled=yes dst-address-type=!local
dst-port=!80 in-interface=LOCAL new-connection-mark=WAN2_conn
per-connection-classifier=both-addresses-and-ports:2/1 protocol=tcp
“Excluding Port 80 from PCC WAN3” disabled=yes dst-address-type=!local
dst-port=!80 in-interface=LOCAL new-connection-mark=WAN3_conn
per-connection-classifier=both-addresses-and-ports:2/0 protocol=tcp
add action=redirect chain=dstnat comment=“Web Proxy” disabled=yes dst-port=80
protocol=tcp to-ports=8080
add action=masquerade chain=srcnat out-interface=WAN3
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
/ip proxy
set cache-administrator=ambikapur@isolnet.in cache-on-disk=yes cache-path=
“Sony HDD”
add check-gateway=ping distance=3 gateway=192.168.1.251 routing-mark=to_WAN1
add check-gateway=ping distance=2 gateway=192.168.2.251 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=45.112.22.65 routing-mark=to_WAN3
add distance=1 gateway=45.112.22.65
add distance=2 gateway=192.168.2.251
add distance=3 gateway=192.168.1.251
Thank you for reply
