RB751 2Hn Antenna B registers and WLAN EEPROM Registers
We’re evaluating the 751s as a replacement platform and need detailed information on the AR9283 EEPROM registers to set the unit into a chain mask 1, antenna B mode.
We’re not using RoS, but compiling our own kernel and ath9k.
We can see that setting the the unit to Antenna B in the RoS UI, and only chainmask 1 clicked, we get the results we need, ie the transmit/receive on the MMCX connector at full power. However, we do not know how /what register values to throw at the AR9283 EEPROM to get the external switch to work as needed. Can someone expose that information on the hardware?
We also would like the WLAN LED to be toggled by the ath9k driver, and wonder what registers the LEDs are set to for showing activity
Any help is appreciated!
