rb751-2hnd
Just received this wonderfull piece of hardware for the office, but I’m planning to buy at least one for my home.
Someone know what is the lowest operating frequency of the radio chip inside the router?
Can it do some frequency in the 2.3 to 2.4ghz band? I can’t seem to find this information anywhere, but in routeros you can activate frequency in that band with SuperChanel mode.
Thanks for your help.
If RouterOS shows it, the device supports it. With superchannel you should be able to use 2.3 or even a little lower. This command will show the actual supported frequencies:
/wireless info print
many thanks :slight_smile:
