RB751 gets led 1 green (always on)
Hello guys, im working hardly in one solution with fail over and openvpn client and i find out a problem with rb751 running RouterOS 5.14, to be honest i dont know if is a bug or some hardware limitation, but here is the thing:
If you start the rb751 with the default configuration it gets:
Ethernet 1: Gateway Wan, DHCP Client, some Firewall rules
Ethernet 2: Master Port Lan, Bridge, DHCP Server
Ethernet 3, 4, 5: Slave from Ethernet2
Connecting my ADSL Router on the Ethernet1 the board gets the IP properly and i can surf one the web, next i set the NTP Client using the IPS 139.82.34.44 and 200.20.186.75, ok so far the time is set properly as well, then now when i set the PPP connection for my 3G Stick (Huawei E173 it have support by default) it connects fine too and im able to ping IPs through the PPP Connection.
But now when i reboot the system or turn it off, the board does not get up with its interfaces and the led 1 gets always green without blinking and i cant access de board again, and i have to reset the board by pressing the reset botton and do all the work again.
Does anybody have the same problem? can someone help me out with this issue? I really dont get the problem and im afraid its a bug.
Thanks,
Regards,
Thats strange. You might want to email support@mikrotik.com
cbrown, thanks for the reply.
I’ll send the e-mail to them, but hopefully someone here can help me out too.
Thanks,
