Hello to all .
What i must activate ( except the antenna b ) to make it work with external antenna ?
and what to disable ?
Thanks ![]()
Hello to all .
Thanks ![]()
Deactivate HT Tx Chains chain0 and select antenna b.
already tried that but no success ![]()
That’s wrong, deactivate Chain 0 causes for me in broken sessions and my stations disconnects… activate Chain0 all works fine.
You need to leave RX on chain0 enabled, you can disable the TX on chain0 if you want to use only chain1.
I said only Tx Chain0. If you have a directional antenna mounted on mmcx this is the best solution.
For me it’s working this way but i only have 27dbm if i deactivate tx on chain0.
So what is the solution ? Deactivate chain0 TX and activate chain1 TX ? And use antenna B ?
So you have to deactivate chain0 tx, activate chain0 rx, both chain1 rx,tx activate and select antenna b.
That’s it!
