How does the RB751G-2HnD come configured out of the box. I have recommended this to a friend who has no RouterOS experence and will be using it for a SOHO. I figure as its being sold as a SOHO router it will come set to do DHCP on the WAN side on port 1 and a default DHCP server on the LAN side with all the settings you see typically set for a normal linksys type soho router.
Is the default config setup this way ? Like a RB750G comes ?
Also how does the wireless start off configured ?
