RB751G-2HnD mmcx male or female ?
Can someone help me confirm whether the mmcx connector on the RB751G-2HnD is a male or female connector ? The pin in the middle is so thin but hollow. Thin enough that it looks like a male to me but as the pin appears to be hollow, it could be a female.
I want to attach an external SMA antenna via an mmcx > sma adaptor and thus need to confirm this.
Thanks.
fy
SMA or RP-SMA?
Most wifi antennas are RP-SMA is why I ask.
http://www.streakwave.com/itemdesc.asp?ic=RSMAMMCX&eq=&Tp=
This would work for a standard wifi antenna. I can’t seem to find one with a standard SMA connector.
I believe it is RP SMA. This is the antenna I have.
http://www.alfa.com.tw/in/front/bin/ptdetail.phtml?Part=ARS-N19M&Category=106129
I think I need the following adaptor.
RB751G <> [mmcx (female) to RP SMA (male) adaptor] <> antenna
or should it be
RB751G <> [mmcx (male) to RP SMA (male) adaptor] <> antenna
So that is why I need to confirm whether the RB751G external mmcx connector is male / female
Anyone can confirm ?
Anyone ?
I see that the external connector is an MMCX Female!
