I was hoping for actual throughput of 15-16 megabytes per second. Well, I’m close. I moved the client closer to the router (about 2 meters away from it now) and I’ve been regularly getting around 13-14 megabytes per second. The connected tx/rx rate of the client fluctuates quite a bit, but it’s usually ~270-300Mbps for the majority of the time. When it’s in that range, I’m getting my best transfer rates.
Here’s my current config for anyone who wants to have a go at it:
# aug/23/2012 23:16:56 by RouterOS 5.20
# software id = Y71M-33GF
set [ find default=yes ] authentication-types="" eap-methods=passthrough \
group-ciphers="" group-key-update=5m interim-update=0s \
management-protection=disabled management-protection-key="" mode=none \
name=default radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
static-sta-private-algo=none static-sta-private-key="" \
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" \
wpa2-pre-shared-key=""
add authentication-types=wpa2-psk eap-methods="" group-ciphers=aes-ccm \
group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=dynamic-keys name=\
myWiFiNetSecurityProfile radius-eap-accounting=no radius-mac-accounting=no \
none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=\
myPreSharedKey wpa2-pre-shared-key=myPreSharedKey
management-protection-key="" mode=dynamic-keys name=GuestSecProfile \
"" wpa2-pre-shared-key=2354guest
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 \
antenna-mode=txa-rxb area="" arp=enabled band=2ghz-onlyn basic-rates-a/g=\
48Mbps,54Mbps basic-rates-b="" bridge-mode=enabled channel-width=\
20/40mhz-ht-above compression=no country="united states" \
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=\
0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=\
no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=2412 \
frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no \
ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-amsdu-limit=8192 \
ht-amsdu-threshold=8192 ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any \
ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-\
6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-1\
7,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0,1 \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
00:0C:42:FB:B7:2B max-station-count=2007 mode=ap-bridge mtu=1500 \
multicast-helper=default name=myWiFiNet noise-floor-threshold=default \
nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" \
nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
on-fail-retry-time=100ms periodic-calibration=default \
periodic-calibration-interval=60 preamble-mode=both \
proprietary-extensions=post-2.9.25 radio-name=000C42FBB72B \
rate-selection=advanced rate-set=configured scan-list=default \
security-profile=myWiFiNetSecurityProfile ssid=myWiFiNet \
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
48Mbps,54Mbps supported-rates-b="" tdma-period-size=2 tx-power=13 \
tx-power-mode=card-rates update-stats-interval=disabled wds-cost-range=\
50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no \
wds-mode=disabled wireless-protocol=802.11 wmm-support=disabled
/interface wireless manual-tx-power-table
set myWiFiNet manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,\
9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-\
0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17\
,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT4\
0-7:17"
/interface wireless nstreme
set myWiFiNet disable-csma=no enable-nstreme=no enable-polling=yes \
framer-limit=3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
btest is showing about 35Mbps (megabits per second) but real-world transfers are showing the higher rate. I’m not sure what that means, if anything. I’m able to transfer large files quickly though, so that was all I was hoping to accomplish.
btest results:
Windows Samba copy results (transfer 1):
Windows Samba copy results (transfer 2):
Not quite what I was getting earlier today, but currently I’m listed as being connected at 243Mbps instead of the full 300Mbps so I guess that could account for the slowdown.
I might try to set it to Only-N and try again, see if it gets more stable. It turns out I only have one .11g client machine left, so I guess it might be time to upgrade it.
