RB751G-2HnD switch
I have a strange problem with RB751G-2HnD. The switch can’t handle more than 10mb/sec bandwidth between mac client and freenas server. On the other hand if I use a dlink switch I can transfer over 60MB/sec. I have tried disabling any queues. Version 5.24. I use a bridge for wlan-ethx
Make sure the ports are linking up at 100mbps and that your using switching not bridging. You switch by setting the master port option. You bridge under the bridge section. Bridging should work fine but switching is more efficient.
