Hi
I have a Mikrotik RB751G.
As you know this may has gig ports and I have read that it should be able to have over 600Mbit throughput WAN to LAN.
I have a 500/500Mbit internet connection but I’m only getting about 150/150 through the router. When I bypass the router I get full speed.
I use the default NAT configuration, some rules for port forwarding and a static IP provided from my ISP. WAN on ether1-gateway and LAN on ether2-master-local.
I’ve tried different TP-cables. Cat5e, cat6, shielded, unshielded, you name it.
Is this router unable to perform better? In that case I’ll have to look for another ![]()
