Hi there ,
i am totally new to the microtik world. I have a RB751U-2HnD and bought a TP-Link Adaptor - TL-WN881ND ( not dual band, 300mb). So i am trying to set the connection between them to 300mb, but can only achieve 150mb. I have played allot with TX power and different antenna chains, but the max speed i get is 150mb (real test speed is 65-70mb) so i have no idea what am i doing wrong. Have tried to set only N-connections and other options regarding Channel Width, but no success. The two adapters are in the same room, 2m away. If someone can help me, it will be great. I have searched the web, parts of the forum too, but have not found a direct answer/solution for my “problem”
Any help will be appreciated greatly !
Thanks in advance.
Sure i dont need more than 100mb , but i am curious. I am doing somthing wrong and i want to know what. I am sure i cna reach that speed with that router and i want to know how.
Do not forget. 100 Mbps is a physical speed. Real traffice is less by 25% for overhead of the TCP protocol. So you will never achieve faster than 75-80 MBps. And if you have that, it is very very good, especially on 2,4 GHz.
HD streaming is max 20 MBps. So you can easily watch 2-3 HD “streaming pictures” (the word which starts with “mo…” is not allowed to be mentioned in the post) at the same time.
In practice: only one HD film streming is posisble.
