Hello everybody !
First of all, I want to apologize for my first noob post and my poor english.
I bought 2 units RB751U-2HnD, one is bought in Canada from Xagyl and another is from Slovakia Alza. I should read some forums before buying these units.
Lets start…
my setup:
Alienware m17x R4, Windows 8 64-bit, 32Gb ram DDR3 Corsair Vengeance, 2x Samsung 500Gb SSD 840 Pro, Ati 7970m 2Gb, Killer Wireless-N 1103 ( laptop wifi ), Qualcomm Atheros AR8151 PCI-E Gigabit ethernet card
- Samsung Galaxy S4
- Samsung Galaxy Nexus
- PS3
- Goflex NAS ( 2Tb )
- QNAP NAS ( 2Tb )
- 2x RB751U-2HnD
- Thomson TWG870UIR
- some TP-Link ( too lazy to get model number )
If I am connected to Thomson via wifi on Alienware, wifi shows 300Mbps and internet speed test shows about 68Mbps down and 45Mpbs up
If I am connected to Thomson via cable, internet speed is + - 20% same
RB751U-2HnD
If I am connected to RB751U-2HnD via wifi, internet speed test shows about 4 ( yes FOUR ) Mpbs down and up about 8 ( yes EIGHT )
same with Samsung Galaxy S4, Nexus and other devices…
same results with cable connection…so the bottleneck is RB751U-2HnD !!!
any device connected to Thomson or TP-Link shows maximum internet speed ( more or less )
I had RouterOs 5.25 then upgraded to 6.3 then upgraded again to 6.4 without ANY difference, same problems and same speed
RB751U-2HnD is running in “quick set” as AP or in “quick set” as Home AP, no queves, no special settings…performance is still same…
**/interface wireless print
0 R name=“wlan1” mtu=1500 mac-address=xx:xx:xx:xx:xx:xx arp=enabled
interface-type=Atheros AR92xx mode=ap-bridge ssid=“MT” frequency=2412
band=2ghz-b/g/n channel-width=20/40mhz-ht-above scan-list=default
wireless-protocol=802.11 antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=profile1
compression=**n
basically, I have 2 bricks with “Mikrotik” brand on it, but cant use it, because performance is 10x worse then TP-Link or Thomson for less then half price of Mikrotik
I will be very happy for any help. I tryed almost everything I have found on any forum about RB751U-2HnD. Maybe I should buy RB951G-2HnD, because RB751U-2HnD is just a big joke.
Paid about 120euro for 2 devices, which dont work as they should.
If somebody has some “good settings” script for RB751U-2HnD I can try it and test it.
Only good thing I was really impressed on RB751U-2HnD is unbelievable Wifi range.
cable connection to RB751:
wifi connection to RB751:
cable connection to Thomson:
wireless RB751:
http://imgur.com/RpO5noY
Speed TEST screens:
RB751:
Thomson:
