RB751u-2HnD reboot on Skype and FaceTime
Hello I have a RB751u-2HnD with version 5.14. The device always restarts after I initiate a Skype or FaceTime video call. Then when I reconnect it works fine. How can I fix this? This is extremely annoying.
Thanks,
The way to reset your router or do an upgrade to the next version → 5.15
Test with v5.15 where some issues were addressed already
Normis, this thing doesn’t work. Now it just reboots randomly. Who can fix this?
mine resets when downloading with flashget (5 or more threads). 1 is ok…so far… ghhh
Very uncool
Guys, if you did what I asked (upgrade to v5.15) then please send us more info, Attach supout.rif file and email to support. We can only fix the issue, if you give us information.
Yes, I did it and I already sent a support file.
My RB751u-2HnD reboots 1- 2 times per week. I just performed upgrade to Router OS 5.16, let’s see what’s will happen.
But it’s unfortunate that it has this behavior - we plan rather large rollout of 16 RB751u-2HnD devices, it should be solved before.
You will then restart, the device itself? If so you may have a thing wachdog settings
@runic keep us posted on your results. I will update my device however I am not using it as part of my network anymore…
