RB751U-2HnD restoring configuration
Hi, I have an 751g 2n and i have loaded an back up from 433 but now is not working any more how to go to initial set-up ? thank you
Do not load backups generated on different routerbaord models. Use “export compact” → “import” instead to transfer configuration. Try resetting router with this method: http://wiki.mikrotik.com/wiki/Manual:Password_reset or reinstall using Netinstall: http://wiki.mikrotik.com/wiki/Netinstall
Thank you, now I have another problem, i am trying to use samba on this device, but the attached 2tb but i am not able to format the drive, always i get the error, Than you
