RB751U-2HnD - Single port configuration
Would it be possible to run following features on the single port eth1?
VLANs (1WAN, 2LAN, 3WiFi)
NAT (LAN,WiFi to WAN)
DHCP for LAN and WiFi
use Poe to power the RB751
It’s not the best possible solution but I’ve go just one cable from the switch to the router which I’d like to use as an access point.
Thank you in advance for your help
