RB751U-2HnD TX Power!
I bought “RB751U-2HnD” couple days ago and I have noticed that the software only shows the TX Power as 27dBm but the website http://www.routerboard.com shows that its TX Power is 30dBm .
I tried to override the settings to 30dBm but the softwre only shows 27dBm even if we played with its tx power.
Is it by default 27dBm which means 500mW ?
I bought the product from ( SKIES PRO - LEBANON )
Ghassan
RB751U-2HnD has two chain ‘n’ wireless chip.
27dB per chain gives 30dB total.
Set Tx power to 27dB and check ‘Current Tx Power’ tab in Winbox.
HTH,
maybe is the offset 3 db offset
