Is any way to do load balancing between two usb 3g Modems (UM175) conneted to RB751U-2HnD USB port via usb 2.0 HUB ?
Yes, I believe you should be able to do that just like with any other type of ISP. Just set up both modems as separate ISP’s at the same time and follow the load balancing guides in the wiki.
