RB751U-2HnD - which to better position
How is the lobe of irradiation of the RB751 2hnd? Is It omnidirectional? And the AP in the vertical position is it going to transmit omnidirectional or by sector? Or in the indoor use is not going to do difference in the AP position?
no diference on interiors location and short link. only if you want to do a point to point conection.
Ok, but as is the lobe of irradiation? If the AP is in the vertical position is it bidirectional and itself is in the horizontal position is it omnidirectional?
I am going to use it in outdoor for more or less 100 meters.
I found this router to have a poor internal antenna - CCQ is very low, the specs say you need an MMCX connector but I’ve had a really hard time finding a connector that fits.
Thank you very much by the feedback
Efectectively for 100mts is not enouch anttena, i use this http://www.flyteccomputers.com/details.cfm?wid=654&wb=StationBox%202,4GHz this have a mmxc conector for rb751, select the antenna b on mikrotik and work very good.
