I have you send a config file.
I main that you must delete the wlan into bridge ports.
Hello ,
it’s official , my router is dead , your config burned it
, even manual reset not working . Maybe was a chineese version
A configuration file can’t blow up your routerboard.
Have you reset the routerboard and deleted default configuration?
I help you further with mail conversiation.
look what i have done ; i started the config the hotspot on this base
http://netwanlan.com/2012/04/04/configure-hotspot-server-in-mikrotik/
same example , and it is working fine . After i have use your exple on this page to configure the internet on Eth2,3,4,5
http://www.wirelessinfo.be/index.php/mikrotik/pages/ap
i have not include wlan on bridge-lan while doing it and the two interface group ( wlan ; eth ) get different ip address range )
Now Hotspot is working on WLAN and INTERNET IS WORKING ON LAN PORT
