does RouterOS (RB751U-2HnD) support the D-Link DWM-156 UMTS stick?
Did anyone test it?
greets, Markus
Did anyone test it?
greets, Markus
It is not listed on the supported hardware page, so all you can do is plug it in and try it.
The hardware-compatibility list I have already checked.
But I won’t buy it if it’s not supported. ![]()
what about ZTE MF110 … i am considering buying one board !
Again, check the supported hardware page. If it isn’t listed, then all you can do is try it and see…
isn’t it possible to get a test sample and see if it is or is not working?
I don’t know how you would get a test sample of a modem. Some companies will allow you to return within 14 days, but that’s all I know of.
i found ZTE MF112, mine it’s 110
)) will it work…?!
hi. i am test it with rb2011 but not any interface add in interface list and it not work!
