RB760iGS 7.8 + USB 4G LTE USB not running
Hi every one.
I have some trouble while I using Marvell base USB 4G modem on RB760iGS. The LTE interface show up but never running, and couldn’t create DHCP client using LTE(there is no LTE option).
The 4G modem work well when I connect laptop or phone to it’s Wi-Fi. They could get 192.168.x.x IP address directly.
Could someone help me out? It would be really greatful.
There are some screenshots.
For LTE, the IP address is not obtained through DHCP. Instead you should check that your APN profile matches the settings required by your provider. Most if it is pretty standard, but the APN may vary from provider to provider. From your screenshots it appears you have a default profile, but you might want to check if anything needs to be changed for your provider.
