Hello everyone!
I have an RB760iGS router and a Huawei E3372-325 USB modem that MikroTik does not recognize.
When i put this modem to notebook - it works. but in devices i dont see how to directly get access to modem whith at commands
RouterOS only includes a few drivers for auxiliary devices … and you can not add your own. Latest ROS v7 (v7.11 or even 7.12rc) are way better than earlier versions (e.g. v6.X), if you don’t already you may want to run that on your RB760.
When it comes to various USB modem sticks, they may work fine in ROS, but have to be configured to a particular mode before using them in ROS (ROS doesn’t perform mode switch for most of devices). Perhaps somebody else with experience with particular device will come by, otherwise you’ll have to search internet for “recipe” how to do it.
The -325 is only supported on ARM CPUs (https://help.mikrotik.com/docs/display/ROS/Peripherals). Your hEX S has a MIPS CPU.
Yes. U right
Working on hap router
