Greetings,
I am seeking assistance in resolving an issue with a recently configured hotspot utilizing a hEX RB750Gr3 router. The hotspot was established with four bridged ports and one dedicated WAN port. A Linksys 8-port PoE switch is connected to one of the bridged ports, which in turn provides connectivity to seven Aruba Instant On AP11 access points. A guest Wi-Fi network (open and without a password) has been configured on these access points.
Initially, the hotspot operates without any problems. However, after a certain period of time, the Wi-Fi connection begins to intermittently disconnect and reconnect. This issue does not occur when connecting directly to the access points via a wired connection, bypassing the Wi-Fi network.
As a troubleshooting measure, I tested the setup using a TP-Link Wi-Fi extender configured as an access point. In this configuration, the Wi-Fi connection remained stable without any intermittent disruptions.
I kindly request your expertise in identifying the root cause of this issue and providing a suitable solution to ensure uninterrupted Wi-Fi connectivity through the Aruba Instant On AP11 access points.
Thank you for your attention to this matter.
