configured with ppoe client internet - Internal dhcpserver 172.16.0.0/24 nat active
all internet browsing works perfectly
But I can’t access any network maq or a printer on the network I try to ping and it doesn’t find the network maq.
You know what could be going on.
(1) This is a setting I rarely if ever see, suggest unless there is a reason to remove it… /ip firewall connection tracking
set tcp-established-timeout=30m
(2) HERE IS THE MAIN PROBLEM
add address=172.16.0.1/24 interface**=ether5-Rede_local** network=172.16.0.0
TO:
add address=172.16.0.1/24 interface=REDE_LOCAL_PONTE network=172.16.0.0
(3) The IP DHCP CLIENT should be DISABLED, your WAN is through the pppoe interface!!! /ip dhcp-client
add disabled=no interface=ether1-Redel
(4) Assuming 8291 is your winbox port, REMOVE IMMEDIATELY THIS IS A SECURITY RISK!!! add action=accept chain=input dst-port=8291 in-interface-list=OPERADORAS
protocol=tcp
You should never access the winbox port directly from external www. Change to something like add action=accept chain=input dst-port=8291 in-interface=REDE_LOCAL_PONTE
protocol=tcp
If you want to remotely configure the mikrotik, then use wireguard to tunnel into the router and then access winbox.
Thanks, I made the changes and even so something blocks the ping between the machines, I’m suspicious of the ppoe connection - but I’ve looked at the route and it doesn’t seem to influence anything.
I even changed the internal ips to 192.168.0.0/24 to see and nothing
I did a test by putting a wifi router in bridge mode connected to the mikrotik and the maq behind this router are normally - without it it is not.
could it be anything else?
I noticed that if I connect vpn everything will work maybe it could be something in ppp or route - follow ppp file rota.pdf (71.1 KB) ppp.rsc (586 Bytes)
