hi
what is the total amount of r5h cards that can be fitted to the r800 board
what would a good power supply be that can run all the cards and the board
24v-1.6a or 48v-1.6a poe?
thanks
I test it with eight mixed high power card ( R5H,R52Hn,XR2 ) and it work fine. Power consumption ~40W over Jack and ~55W over POE
what would the right power supply be
thanks
also, would you recommend the rb600 or the rb800?
thanks
RB800 is more powerful. Use 48v-1.6a with Jack or POE
Just wondering. How do you solve self interference problems. 8 cards on one board
with 8 pigtails in one housing (with 11n even more)… I would expect complete unpredictable results.
So does it make sense?
No, I just testing power, how powerful is it how many power it take. Does it reboot at max. TX load or not. In real situation it’s posible some RF interference depend on what case and what pigtails you use.
