RB800 CPU Temp.
I use the rb800 indoor and the cpu fan very loud!
Now I have connected the fan from the 5.5V Jumper to the 3.3V Jumper and the
fan noice is much better - the temperature is between 83C and 90C. Is this OK or is it too hot?
Thanks,
velvet
UPDATE: I upgraded to ROS v4.5. Now, the board shows the correct cpu temp (60C). Everything works fine!
We believe we have temperature issues:
http://forum.mikrotik.com/t/rb800-big-outdoor-case-ca-otu-4xubnt-xr5-temp-issues/36692/8
