I no longer know what to do to solve the problems I’m having with an RB800 it came with version 4.5 that had constant disconnection problems of wireless clients, this system is solar powered by a 2.5 mm cable of about three meters and with version 4.5 to measure the voltage was correct, but the problems presented in the wireless interfaces decided to try other versions, I did downgrade to 4.11 where the problem of wireless interfaces are solved, but the voltage measurement was wrong on two volts less generating another problem as well as the tension became very next ten volts of threshold voltage, then did an upgrade to version 5rc7 which fixed the problem but the tension was one of the wireless interfaces with very high latency. I do not know what else to do to fix both problems for already experienced four versions (4.16 was unstable in the wireless clients) and none solved both problems.
Att.: Marlon Luis Larger
