Hi
I am having an issue with a backhaul link. Currently we have a ptp with RB411AH Boards with R52hn cards. Link is about 5 miles solid rssi at - 50 using 40MHz channels I have 300Mbps solid with 100 percent ccq both ways. If I bandwidth test between the two units I see great udp and tcp traffic when we run it in production it seems to peg out at 60-70Mbps tops in one dire tion. I would expect to see 90ish as that would max out the ether port. I was wonderig if it was the 411ah not being able to handle the load so I got a pair for 800s just wanted some feed back if I was on the right path.
