RB800 & RB604 & 8 X R52HN Quality of Performance: multi Q
(1) can 8 x R52HN miniPCI be mounted on RB800 together with RB604 concerning space? if not, what are my options?
(2) 8 MIMO 90° Sector antennas will be hocked on - one to each R52HN - 4x2.4 & 4x5.8 - will the RB’s handle mimo radio powers?
(3) if running 8 mimo sector and 8 r52hn on each of RB800 of the below pic: will RB at Position A1 still perform well?
— another question is how many of RB800 can be repeated without effecting the true performance of A1
thank you,
(4) what if the RB800+RB604 locks for whatever reason? All your network will be bringed down? Will 8x RB411AH (or 4x RB433AH) be too much more expensive? You would get the rid of all the internal interferences if u separate the radios in different enclosures..
that’s why I ask these questions before I go ahead and make it - because once it’s assembled & mounted it’ll be harder to change..
now, can RB800 hold 4 R52HN considering space?
also, I believe R52HN has some 350mw, is there any other radio at 1000mw that’s made by RB? but 4 can fit on RB800?
thanks,
we could not run 4 hn cards on rb800 without problems
in that case, why would routerboard.com had built this motherboard in first place that supports 4 radios simultaneously?
RB800 is the best choice for running 90° sectors… and since there been antenna’s made supporting mimo, hn radios is a go ahead for such scenario.
i would wish to know why RB800 should not run 4 hn radios ---- what if we try to separate radios by some sort of aluminum plastic rap to limit the interference with each other?
thanks,
