RB850Gx2 memory
Hello, so although on specs http://routerboard.com/RB850Gx2 it says that this router is equipped with 512mb ram, mine has only 470total and free 450.. ?
Btw, I notice the same issue on my new 850Gx2 running 6.27.
I suppose it is just a problem of routeros reporting wrong values,
but a confirmation from Mtik stuff wouldn’t hurt.
Mikrotik support reply
The line displays the total available RAM except the RAM used for the RouterOS
subsystem. Ie. the available memory for user.
Total is still 512MB as indicated.
Regards,
Normunds R.
So it seems that it;s a normal behaviour
