A significant drop file transfer performance via the software bridge.
I spent a lot of time to understand what was happening- File Transfer is up to 20-30MB/s (Megabytes/s). Pings are going well (without losses and delays), but the speed of transmission is very low.
I came to the conclusion that the blame for the change of order packets. When the load increases RB850Gx2 begins to reorder packets.
I took my second router 951G-2HnD and set up the same way. Transmission rate increased 5 times to 800mbit/s!
I repeat - the transfer goes through a software bridge! The “ip firewall” is turn off for the bridge.
Appropriately router/firewal/etc setting do not play any role.
I can assume that 2 cores incorrectly parallelize traffic.
bin/iperf.exe -s -u -P 0 -i 1 -p 5001 -f m
Server listening on UDP port 5001
Receiving 1470 byte datagrams
UDP buffer size: 0.01 MByte (default)
[152] local 192.168.80.20 port 5001 connected with 192.168.80.101 port 56337
[ ID] Interval Transfer Bandwidth Jitter Lost/Total Datagrams
[152] 0.0- 1.0 sec 1.19 MBytes 9.97 Mbits/sec 0.000 ms 1432108360/ 848 (1.7e+008%)
[152] 1.0- 2.0 sec 1.16 MBytes 9.70 Mbits/sec 0.000 ms 0/ 825 (0%)
[152] 2.0- 3.0 sec 1.17 MBytes 9.84 Mbits/sec 0.000 ms 0/ 837 (0%)
[152] 2.0- 3.0 sec 3 datagrams received out-of-order
[152] 3.0- 4.0 sec 1.19 MBytes 9.96 Mbits/sec 0.000 ms 2/ 849 (0.24%)
[152] 3.0- 4.0 sec 6 datagrams received out-of-order
[152] 4.0- 5.0 sec 1.19 MBytes 9.98 Mbits/sec 0.000 ms 0/ 849 (0%)
[152] 4.0- 5.0 sec 2 datagrams received out-of-order
[152] 5.0- 6.0 sec 1.17 MBytes 9.83 Mbits/sec 0.000 ms 0/ 836 (0%)
[152] 5.0- 6.0 sec 1 datagrams received out-of-order
[152] 6.0- 7.0 sec 1.19 MBytes 9.98 Mbits/sec 0.000 ms 0/ 849 (0%)
[152] 7.0- 8.0 sec 1.19 MBytes 9.98 Mbits/sec 0.000 ms 0/ 849 (0%)
[152] 7.0- 8.0 sec 1 datagrams received out-of-order
[152] 8.0- 9.0 sec 1.19 MBytes 9.98 Mbits/sec 0.000 ms 0/ 849 (0%)
[152] 9.0-10.0 sec 1.16 MBytes 9.71 Mbits/sec 0.000 ms 0/ 826 (0%)
[152] 9.0-10.0 sec 1 datagrams received out-of-order
[152] 0.0-10.0 sec 11.8 MBytes 9.88 Mbits/sec 0.000 ms 2/ 8419 (0.024%)
[152] 0.0-10.0 sec 16 datagrams received out-of-order
With the device 951G-2HnD no reported “out-of-order” ![]()
