Hello to everyone,
I have a question, i had 2 new rb850gx2, using 24V@1,2A power into the power jack. accessing the rb via a 1Gb switch.
The access is very too slow, after about 2 minute appear the interfaces. impossible to configure and obviously to use!
Maybe I make some mistake or there are some info unknown that I had to know for a fastest access to the RB?
Any info appreciated.
p.s. on any of the RB I had the same problem. maybe but I belive, sure , I do something wrong with this RB.
Thank you,
rb was connected only to my pc for configuration.
after some retryes the only solution is use the same address of the rb, access to it via ip address and NOT via mac address.
Winbox doesn’t work with this RB if you try to access via mac address.
