Are you sure you did that? Reset button has dual function.
Using: unplug the device power, hold the button, apply power and wait until the USER LED starts flashing. Now release the button to clear configuration.
Note: If you wait until LED stops flashing, and only then release the button - this will instead launch Netinstall mode, to reinstall RouterOS.
Aha, I didnt release the button until after the LED stopped flashing. I will try it tomorrow (dont have the equipment with me atm). But then again, where is the info around this? If I hadn’t gone here for answers, where could I have gone? There weren’t any manuals on the equipment I bought, and the manuals that I posted above didnt say anything about that.
This one explains how you do it With all the 900 series ones. Perfect, a precise manual for the exact series I have !
Now, do tell where that is stated in that document.
I will give you a massive hint: Its not.
All it says is that you should short-circuit a point on the board (which is not even there).
