RB911G-5HPacD-NB problems and settings
does anybody know what the tx power is when it is set to default
it does not make sense to try and tune a link when you can not see what you are doing
why is it not possible to use card rates anymore as fixed rates don’t work properly
it is like the new ros is only made after the hardware is made and then the 2 don’t work together
