Is it true that RB911G-5HPacD doesn’t support CAP?
As far I can see CAP is only supported from RouterOS L4 and the product page shows that RB911G-5HPacD has RouterOS L3.
If so, is it possible to upgrade one level higher?
yeah sure, you can upgrade your level, you can buy the license from the website
