RB911G-5HPacD - NO WLAN
I have a Routerboard RB911G-5HPacD
When I’m going to setup there is no wlan option. You add the bridge, add ether port and no wlan, not showing wlan anywhere, interface list etc.
I tried to reset but did’t work.
It is a factory problem or I still can save this board?
Did you tried netinstall?
Also, make sure your wireless package is installed and enabled. This is found in the System → Packages menu
“Also, make sure your wireless package is installed and enabled. This is found in the System → Packages menu”
I already did that, no success
