I have upgraded to RouterOS 6.1, firmware 3.07, and an L4 license.
Currently running in simple bridge AP mode.
I’m unable to get the five user LEDs to do anything, no matter which settings I use. Anyone have a similar problem or resolution?
Thanks!
Thanks!
In RouterOS v6.1 LED presets start working after the reboot.
This will be improved in the next version to make them work immediately.
Alright, did the reboot and they work now as you advised. However, two things:
I was hoping to get a meter that would use all five LEDs to scale based on throughput, but it seems I can only get all selected LEDs to light at once.
Given #1 above, if a scaling throughput meter isn’t possible, it would be helpful to allow each of the five LEDs to perform an independent function. Right now it’s all or nothing, so why set all five LEDs to the same function? Why even allow me to set more than one?
Thanks!
