RB912UAG-2HPnD Won't Accept DHCP from RB433G
Hi -
I have a new RB912UAG-2HPnD that I’m attempting to setup.
I plug it into my laptop, run Quickset and define the WiFi and the ethernetport as an automatic via Ether1 only for IP address.
WISP.
I apply it, unplug it, plug it into data line and my 433G repeatedly fills the log with ‘dhcp1 offering lease 172.16.0.62 for E4:8D:8C:18:C7:1E without success’ and I am unable to connect to it.
If I reset it, bring it back to the defaults & try to configure again the same results.
it is running 6.23, my RB433G is running 6.31, I will be updating once I can get it on my network.
Every other device (50 some) is working for some time now.
My DHCP server is:
add add-arp=yes address-pool=dhcp_pool1 authoritative=yes disabled=no
interface=LAN lease-time=3d name=dhcp1
add address=172.16.0.0/16 dns-server=208.67.222.222,208.67.220.220 gateway=
172.16.0.1 netmask=16
am I missing something? or do I have some kind of glitch with my new hardware? I’m using POE G241000B as my power source.
493G, my bad.
Ah. I figured out. The Auto-Config was adding some parameters that I wasn’t using, and that seemed to cause it. Once I got on via MAC I was able to turn that off and it grabs an address like expected.
