does this product compatible with UBNT’s basestation antenna? because i recently have 3 units basestation break their Rocket M5 radios, and i haven’t replaced any of them yet.
YES to both questions, although you might need longer antenna cables for this setup. RP-SMA should be easy to come by, just replace your antenna default cable with a longer one.
one more thing,
RB912UAG-5HPnD + R11e-5HnD are not going to interfere to each other? as they are working on the same band, and too close to each other. i’m planning to use them on different channel though
