RB912UAG physical USB power reset whilst using R11e-LTE
Is is possible to do a power reset on the physical USB port whilst the USB is taken over by the R11e-LTE PCI-E card?
Or would I need to remap the USB port back to the physical USB port first, then do the power reset.
Looking at using the USB power reset feature as the output for a watchdog to power cycle an embedded system, but only external connectivity is over 3G.
Would be nice to be able to do it without having to use a script that would tear down the 3G connection as part of the process.
