I have a sector on a high site that isn’t playing along, most if it is working as it should, clients are connecting etc etc.
But webfig won’t work, our management software (API) won’t work, can’t check for updates (it’s blank), resources show blank.
Now I can log in with Winbox but I can not restart it, it’ll say it’s restarting but it never does. Logging in with mac/telnet is very slow but eventually get’s there and I issue restart command
but it never restarts. I tried using the “download and install” update function but it’s also blank.
The only errors in the log is an snmp time out and a few failed logins from me.
Can anyone assist?
MB
(I think the OS is 6.38/3.33 - we have 4 others on the site that are still working fine)
No way to avoid it. There’s critical processes on the RB that’s not responding anymore, that’s why it’s working intermittently and why some functionality doesn’t work. Eventually the entire RB will stop responding.
You’ll have to make the trip, and whilst you do that trip it may be a good option to install IP-enabled PoE switches too so that you can power cycle remotely
