RB922UAGS-5HPacD -- All wireless clients disconnect
Just deployed 4 x RB922UAGS-5HPacD’s… (netmetal5)
They’ve all had bouts were all wireless clients would disconnect and would not reconnect until the wireless interface was disabled and enabled.
CPU just started acting strangely as I write this its now pegged @ 100% and kicked me out of winbox… Looks like it rebooted itself.
Anyone else having problems with these units?
All are running 6.24 w/ routerboot 3.17.
I should also add they’re all running the wireless-fp package as it appears that was enabled by default from the distributor.
please make a support output file from the device when the CPU is 100% and send it to support@mikotik.com
Also try to use Tool Profile to check what module is using the CPU.
