RB941-2nD does not pass 20MBs Wireless
Boa noite, tenho uma RB941-2nD RoS 6.41.4, já fiz todas as configurações possíveis no Wireless porem a banda no celular não passa de 20Mbs, sendo que em qualquer TP-Link 150Mbs 1 Antena, o teste no Wireless passa fácil os 40Mbs, fiz e todos os celulares com 1 antena a banda não passa de 20Mbs, porem celular com 2 antenas como Samsung S8 e Iphone 6 banda ultrapassa 70 Mbs normalmente.
by: Google Translate
Good night, I have a RB941-2nD RoS 6.41.4, I have already made all the possible configurations in the Wireless but the band in the cell phone does not exceed 20Mbs, being that in any TP-Link 150Mbs 1 Antenna, the test in Wireless passes the 40Mbs easy , I did and all cell phones with 1 antenna the band does not exceed 20Mbs, but cell phone with 2 antennas like Samsung S8 and Iphone 6 band exceeds 70 Mbs normally.
6.43rc3
*) wireless - improved compatibility with BCM chipset devices;
Please upgrade and test - fixes soon will be included in current releases as well
Muito obrigado, sempre procurei usar as versões Current, e então ainda não tinha testado a Realise Candidate, atualizei para a 6.45rc5 e deu super certo, Download e Upload no Wifi agora bate 50/50 fácil.. Obrigado novamente.
Thanks a lot, I’ve always tried to use it as a Current version, and so I had not yet tested a Realize Candidate, upgrade to a 6.45rc5 and got super right, Download and Upload not Wifi now beats 50/50 easy .. Thanks again.
yes you only need to use current or bugfix on production environments
6.40.8 (old bridge implementation) and 6.42.1 (new bridge implementation)
also include the same fix
