RB941-2nD port redirect problem
Good day everyone.
I Would like help configuring my RB941-2nD.
I just made a loadbalance for 2 links, 1 is ADSL (no bridge) and dedicated link.
All my out coming services ports comes from dedicated and all normal internet access on adsl.
For my servers all in coming and out coming are from dedicated, but if it fails it’s transfer to adsl, same for the desktops on adsl.
But for some reason I can’t redirect my ftp port (21) using nat, if I test the port for open it will say “open” but can’t transfer… same for DVR port.
I can’t understand why RDP and other 6500 port service works fine and the others don’t.
I paste my configuration below, I will be glade with any help.
Model RB941-nD (hAP lite)
Version v6.39.2
On passowrd I changed to ###### and external ip to EXTERNALIP, EXTERNALGATE, etc
jul/20/2017 12:05:11 by RouterOS 6.39.2
software id = VWMR-U2LT
add admin-mac=6C:3B:6B:41:04:D6 auto-mac=no comment=defconf fast-forward=no
name=Wi-Fi
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
country=brazil disabled=no distance=indoors frequency=auto mode=ap-bridge
ssid=medexpress wireless-protocol=802.11
set [ find default-name=ether3 ] name=LAN01
set [ find default-name=ether4 ] name=LAN02
set [ find default-name=ether1 ] name=WAN01
set [ find default-name=ether2 ] name=WAN02
/ip neighbor discovery
set WAN01 discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
“#######” wpa2-pre-shared-key=“#######”
add name=profile wpa-pre-shared-key=visitante wpa2-pre-shared-key=visitante
#add name=dhcp ranges=192.168.88.10-192.168.88.254
#add name=MEDwDHCP ranges=10.1.1.80-10.1.1.99
add name=lanVPN ranges=10.1.2.2-10.1.2.10
#add address-pool=MEDwDHCP authoritative=after-2sec-delay interface=Wi-Fi
name=defconf
/ppp profile
add dns-server=10.1.1.101,8.8.8.8 idle-timeout=5m local-address=10.1.2.1
name=vpn only-one=yes remote-address=lanVPN
/system logging action
set 0 memory-lines=100 memory-stop-on-full=yes
set 1 disk-lines-per-file=100
add bridge=Wi-Fi comment=defconf interface=LAN02
add bridge=Wi-Fi comment=defconf interface=wlan1
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 enabled=yes
#add address=192.168.88.1/24 comment=defconf disabled=yes interface=LAN01
network=192.168.88.0
add address=“EXTERNALIP”/29 interface=WAN02 network=“EXTERNALNETWORK”
add address=10.1.1.1/24 comment=“Ponte com med” interface=LAN02 network=
10.1.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
WAN01
#add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=10.1.1.253 disabled=yes name=router
add address=“EXTERNALGATE” name=RouterDedi
add address=192.168.15.1 name=RouterAdsl
/ip firewall address-list
#add address=10.1.1.103-10.1.1.110 comment=“Lista de Servidores do 103 ao 110”
list=Servidores2
#add address=10.1.1.101 comment=“Lista de Servidores do 101” list=Servidores1
add action=accept chain=forward comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept establieshed,related”
add action=accept chain=forward comment=“Redirecionar: RDP”
connection-nat-state=dstnat protocol=rdp
add action=drop chain=input comment=“defconf: drop all from WAN”
in-interface=WAN01
in-interface=WAN02
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=WAN01
connection-state=new in-interface=WAN02
/ip firewall mangle
add action=mark-routing chain=prerouting comment=
“Grupo: Esta\E7\F5es de Trabalho” new-routing-mark=MED_PCs passthrough=no
src-address=10.1.1.2-10.1.1.99
add action=mark-routing chain=prerouting comment=“Grupo: Servidores”
new-routing-mark=SERVIDORES passthrough=yes src-address=
10.1.1.100-10.1.1.108
add action=masquerade chain=srcnat comment=“defconf: masquerade”
out-interface=WAN01
out-interface=WAN02
working
add action=dst-nat chain=dstnat comment=“Redirecionar: Porta ArtNews”
dst-port=6500 in-interface=WAN02 protocol=tcp to-addresses=10.1.1.106
to-ports=6500
not working
add action=dst-nat chain=dstnat comment=“Redirecionar: Porta DVR” dst-port=
8000 in-interface=WAN02 protocol=tcp to-addresses=10.1.1.130 to-ports=
8000
not working (was disabled when it exported the file)
add action=dst-nat chain=dstnat comment=“Redirecionar: FTP ARQ02” disabled=
yes dst-port=1021 in-interface=WAN02 protocol=tcp to-addresses=10.1.1.108
to-ports=21
working
add action=dst-nat chain=dstnat comment=“Redirecionar: Wemin FileServer”
dst-port=10000 protocol=tcp to-addresses=10.1.1.102 to-ports=10000
working
add action=dst-nat chain=dstnat comment=“Redirecionar: Wemin FileServer2”
dst-port=10001 protocol=tcp to-addresses=10.1.1.108 to-ports=10000
working
add action=dst-nat chain=dstnat comment=“Redirecionar: Wemin FileServer2 SSH”
dst-port=10002 protocol=tcp to-addresses=10.1.1.108 to-ports=22
working
add action=dst-nat chain=dstnat comment=“Redirecionar: RDP” dst-port=10105
protocol=tcp to-addresses=10.1.1.105 to-ports=3389
working
add action=dst-nat chain=dstnat comment=“Redirecionar: RDP 107” dst-port=9999
protocol=tcp to-addresses=10.1.1.107 to-ports=3389
/ip firewall raw
add action=passthrough chain=prerouting comment=
“special dummy rule to show fasttrack counters” disabled=yes
/ip firewall service-port
set ftp disabled=yes
add comment=LinkADSL distance=1 gateway=192.168.15.1 routing-mark=MED_PCs
scope=255
add comment=LinkDEDI distance=1 gateway=“DEDICATEDGATE” routing-mark=SERVIDORES
scope=255
add disabled=yes distance=1 gateway=“DEDICATEDGATE”
/ip service
/ppp secret
add name=daniel password=###### profile=vpn service=pptp
/system clock
set time-zone-name=America/Recife
/system identity
set name=RouterMed
/system package update
set channel=release-candidate
/system script
add name=Link_ADSL-on owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive source=
“/ip route {set [find comment=LinkADSL] gateway=192.168.15.1}”
add name=Link_ADSL-off owner=admin policy=
“/ip route {set [find comment=LinkADSL] gateway=“DEDICATEDGATE”}”
add name=Link_DEDI-on owner=admin policy=
“/ip route {set [find comment=LinkDEDI] gateway=“DEDICATEDGATE”}”
add name=Link_DEDI-off owner=admin policy=
“/ip route {set [find comment=LinkDEDI] gateway=192.168.15.1}”
/tool mac-server
add interface=WAN02
add interface=LAN01
add interface=LAN02
add interface=wlan1
/tool mac-server mac-winbox
add interface=WAN02
add interface=LAN01
add interface=LAN02
add interface=wlan1
/tool netwatch
add comment=Verifica_LinkADSL down-script=Link_ADSL-off host=192.168.15.1
up-script=Link_ADSL-on
add comment=Verifica_LinkADSL down-script=Link_DEDI-off host=“DEDICATEDGATE”
up-script=Link_DEDI-on
If you are using passive mode FTP you may need to adjust the external IP of the server during the failure condition. Additionally, you’d need to allow (NAT) the passive IP pool into the FTP server.
When operating in passive mode the server instructs the client on what IP and port to connect back to itself on. The FileZilla FTP server allows you to discover the external IP dynamically. This may work well in your situation.
All in all, FTP is PITA for these kinds of situations. You may find SSH based file transfer as a good alternative. It will provide strong security and be more friendly in these kind of conditions.
idlemind thx for reply.
I undestand but dont rely know how to make this configuration could you help me, I still new on mikrotik configuration.
My FTP server is a linux server with passive mode.
