I want to use my RB951 as a wireless client
Is this possible?
SO connect it to my Wireless netwerk (netgear wireless router).
This will work
remove the default configuration first
follow the step for step procedure
http://www.wirelessinfo.be/index.php/mikrotik/pages/station
If i helped you give me karma pleace
Is this solved?
You could simply open the 192.168.88.1 address in your browser to launch Quickset. There select “CPE” mode.
