RB951-2n and Metal now shipping
RB951-2n and RouterBOARD Metal now shipping to your nearest distributor:
http://routerboard.com/RB951-2n (list price 45$)
http://routerboard.com/RBMetal5SHPn (list price 99$)
The RB951-2n is the home wireless AP you have been waiting for. It has five Ethernet ports and a 802.11b/g/n wireless AP with an antenna built in.
The new, completely waterproof, rugged, and super high powered RouterBOARD Metal. The serious outdoor wireless device. 5GHz 802.11a/n and 1.3W output power
Contact any distributors for more details about availability: http://www.mikrotik.com/buy
Is the 1.5dBi antenna gain on the RB951-2n enough? I think most SOHO routers have a 5 dBi gain.
It works very good even in larger apartments/houses.
Output power is very good. In most countries it is necessary to comply with the allowable output power.
Unfortunately input Rx sensitivity is the same as the Groove.
RouterOS allows you to set country, and it will apply regulations. You can also reduce power to acceptable level if you need to.
Also - The RB Metal is CE and FCC certified.
Ok. You wrote so http://routerboard.com/R5SHPn
we can sell R5SHPn only to countries outside European Union. And RB METAL will be sold where? Thanks
No, R5SHPn card doesn’t have CE. RB Metal has CE. That’s a big difference. So RB Metal you will be able to sell in EU
The RB751U-2HnD says it has 2x2 MIMO PIF antennas, max gain 2.5dBi. It virtually has no gain in my setup and I used it in a SOHO environment. Is this new RB951-2n better or worst?
RB751U is more expensive, larger and has more output power.
RB951-2n is smaller, less expensive and has less output power.
Hi, I know about PoE power output in RB750UP, but does the single PoE port in RB951-2n have power output also? Thanks.
Why RB951-2n naming? Is it a new CPU or completely new model? I would give it RB751L-2n or something like that.
RB751U/G doesn’t works stable for me. Its’ wireless performance is not (so) good compared to other SOHO wireless routers. So I don’t know who is the target for this new device. Other SOHO router manufacturers has several 3x3 MIMO devices with 3 external antennas in $40-$100 range; more expensive ones comes with dual band support 2.4Ghz and 5Ghz. I would be happy to see something similar from MikroTik. I would probably buy one of these 3x3 MIMO + external ant routers… but that RB951-2n is something I can’t trust. - not because it’s bad, but due to bad experiences with 751U-2HnD.
Note: I’m still waiting for RB2011 with wireless. It would be nice to add third antenna and chain to that one. :slight_smile:
Any plans for make a g version of the Metal?
Looks like an ideal device for create a public AP and give access directly to the users (without CPE) but for that, it needs to be able to work in 2.4
Cheers
JD
Ditto
Routerboard Metal sounds fantastic :slight_smile:
However, the problem I see with the Metal is the orientation of N-male connector / ethernet port.
Majority of antenna types have a horizontal connector (in properly installed position).
This means that Metal is impossible to mount on such antennas without exposing ethernet port to weather conditions.
Is it possible to rotate N-male connector for 90 degrees in some future model?
Adding externally additional 90’’ n-female_to_n-male adapter really isn’t solution (increased price and probability of weather isolation’s failure due to additional “weak point” in RF chain).
Metal as a new product is a REALLY GREAT IDEA, but in this form we cannot use it without additional 90’’ degrees adapter or RF cable with N connectors and this reduces some of the main advantages of this new routerboard.
add a 90° Nmale to N female right adapter..
Great job, now if you would add 24 volt poe output on the RB951-2 eth1 to power roof equipment you would have the holy grail of solutions. poe for outside equipment, router and access point. and watchdog to reboot router and poe would be awesome!
Regards,
Josh
I was thinking about the same. There are examples on the forum where somebody put poe on regular ports, somebody else used to solder mmcx connectors in place of internal antennas. So I am wondering how difficult it would be to enable poe output on one of the eth ports in RB951, and whether it is possible at all using standard electronic equipment.
If this device had at least one poe output port it could power the Groove or other CPE. It would be the ultimate hype in every enduser’s hardware installation because it has wireless. Or we just wait for RB951UP and RB751GUP.
I vote for higher gain detachable antennas. Ideally with rp-sma connectors. It’d be more versatile that way..
Dear Normis…
What’s the Ethernet surge protection for the RBMetal5SHPn ?
Any warrantly apply if it damage by the lightning?
and, any additional voltage protection?
How much shielding does this new metal casing offer over the previous Groove?
