Hey guys,
Does the MikroTik RB951-2n support Multicast/IGMP? This is for Cable IPTV.
Thanks.
Hey guys,
Thanks.
only with mutlicast package installed. However some fiddling will be involved and better use static routing in case you go with PIM configuration.
Thank you for the support:). Will check it out.
