I’m having problems getting RB951-2n to work with only ethernet connection with PoE.
According to http://routerboard.com/RB951-2n , the router supports PoE. I have a Cat5e ethernet cable connected to ether1 port, but RB is not getting any power (no LEDs light up). RB is connected to a Zyxel ES-2108, which has PoE-out (if I connect an IP Phone to the cable, it works just fine).
Tried different cables.
ROS is latest (v6.12) and Firmware is 3.10.
I can’t find any settings to do with PoE in /interface ethernet or anywhere else in fact.
Also tried with RB2011, same “result”.
I can’t figure out why it’s not working, maybe you guys have some ideas.
Thank you.
