RB951-2n (v6.12) WPA/WPA2 issues
Hi all,
I have a brand new RB951-2n which I went right ahead and installed at a clients site without testing. This is to terminate an internet connection delivered over ethernet and provide wired and wireless internet access to the client. (ISP managed CPE)
Unfortunately I didn’t test it out in the shop. Assuming that if I set the wifi interfaces up the same way as all the other variations of 951 that I have it should just work. But it didn’t. No client devices would associate with it.
So back in the office I’ve done some comparisons. RB951G-2HnD on the bench, set up with 2 Virtual APs.
2 Security profiles, WPA2PSK and AES the only options. Working perfectly fine.
RB951-2n on the bench next to it. Exactly the same configuration (even same SSID/WPA2PSK secret/wireless channels) Clients can’t connect. (I only have one unit powered on at a time, so no RF interference)
Interestingly If I run without any security it works just fine.
It also does not work with the default configuration as it ships.
Has anyone had any experience with these units having dodgy WiFi?
Clients [HTC Sensation, iPhone 5, Intel centrino Advanced-N 6500, macbook pro all fail to associate. Gave up trying more.]
Config dump:
# jan/02/1970 00:22:50 by RouterOS 6.12
# software id = I079-NW77
add admin-mac=D4:CA:6D:DB:4B:9A auto-mac=no l2mtu=1598 name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
    20/40mhz-ht-above disabled=no distance=indoors l2mtu=2290 mode=ap-bridge \
    ssid=MikroTik-DB4B9E
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
    ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys wpa-pre-shared-key=gimblelock wpa2-pre-shared-key=gimblelock
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
add address-pool=default-dhcp disabled=no interface=bridge-local lease-time=\
    10m name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=\
    bridge-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
    no interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" dns-server=\
    192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" disabled=yes \
    in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=\
    established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway
/ip upnp
set allow-disable-external-interface=no
/system leds
set 0 interface=wlan1
/system routerboard settings
set cpu-frequency=400MHz
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
FIXED!!
I fixed this by upgrading the RouterBOOT bootloader. From 3.07 to 3.10 which is available on the routerboard.com site in the side bar of the product view page along with the documentation regarding the unit.
Now it behaves just like it should.
