RB951 AP Bridge help
A friend gave me this router, i’m not familiar with this many options in a router lol but anyways what i’m trying to do is basic.. i want to have the RB951 connect via WiFi to my WiFi Router supplied by my ISP so I can wire into the RB951 and use it in another room. Instead of running a 100FT Cat5 across my house i just want to be able to wire my devices into the rb951 in another room. Hope this makes sense! thanks a bunch in advance.
Run wire. It’s better especially if it is so big distance through the walls and other obstacles. Anyway to your question. Remove the config. Make bridge. Put all interfaces in it. Set the wlan as station bridge and let it connect to the Ap.
